KCM my Monday came on Tuesday
Coulda been a lot worse. Was only doing 50 on interstate but fortunately she waited until I ramped of and as I began my turn at the stop light I heard a loud bang and thought uh oh. Backed the tractor off and uses a come along to suck it back and crippled it home.
You have to experiment with what way to hold the phone to get the antiquated system to post them right way . I tore the neck off my big trailer one time hauling a 4430 John Deere and 535 round baler pulling a 14 wheel v rake behind that
I have seen several trailers like that lately. My nephew had one and I caught it before it seperated. Welded some gussets and ground out the cracks and rewelded them and put some weld on the inside. Now it's better than new. If you have a trailer with a vertical post you might want to inspect it closely.
I have see flat bed Semi trailers break there frames. The only way to fix it right is to weld it up real good, then put A patch over it by welding it on a angle. If you weld it straight it will break again.
