farmall 400 with a pipe loader
SDE
I think the loader is a IH 33A. Are the pipe loaders strong enough to be used to push snow with a 8 or 10 foot snow blade attached to them? The tractor weighs about 7500 and if I am pushing into a pile of snow and the pile causes the tires to spin, then the loader arms are being forced to with stand a lot of force, especially when I am going to use tire chains.
TY
SDE
I'd say that you were getting on the wide side with an 8 or 10 foot blade for that loader. You would be OK if the snow was dry and loose but if wet and slushy then freezing I don't think that the loader would hold up. I don't know if you have access to a manual for that loader but I would think that a 6 or 7 foot blade would be plenty for a 33A. Put side caps on if the snow needs to be pushed a distance versus a wider blade.
I can't help you with your 33A loader but my SM with a JD45 would handle it. I have a 8ft one for it and it works pretty good. This loader has a weak spot on the upper pipe, just behind the plate that ties to two sides together. It breaks from lifting to much over the years. I reinforced it with 5ft of 1/4in pipe over the pipe frame. It's now almost bullet proof. After a while I added the hyd cylinders for the tilt
The loader that I have, has an arc in the pipe with bridging to re enforce them. With yours being straight, I can see why it is able it with stand the forces applied to it.
TY
I have a blade that I made thirty years ago, for the front of the tractor, but to use it I will need to remove the loader. I thought it would be more convenient to adapt the blade to the loader and just change from a bucket to the blade. The snow is still light and loose here this month, but the next time the snow banks will be hard and that is when I would be likely to damage it.
TY
You might check how wide the factory snow bucket was for that loader. JD #45 was a similar loader, the regular bucket was 40 inches wide and the snow bucket was 80 inches wide.
I would be concerned about damaging the loader frame with a 120 inch wide blade. If you are pushing snow at 4 or 5 MPH and hit a solid rock, large post or concrete foundation with the edge of the blade 3 feet past the outside of the loader frame, the impact could easily bend the loader frame. After that it would be hard to get the bucket or blade level again.
