Found some diale
SVcummins
For the 4020 but bent them up pretty bad trying to load them
Assuming you meant to write Duals. The rings should be pretty easy to re-bend to acceptable roundness A jack across the diameter, or possibly a truck rim used as a form to push them straight with a bottle jack. Jim
Ya auto correct doesnt like some of the lingo that comes with tractor work..
Hope you got a good deal on em.. screw type or rock over clamps?
I don’t know how good a deal it was but i got em need to get em straightened out they are the kind with the cam over type clamp my 3020 has the bolt on type j bolts. Here’s a question for barney since these are cam over type are they legal or illegal for road use 😀😀😐? I got a set of 9 bolt duals from the same guy on the same deal traded pasture for them two plus he wrote me a thousand dollar check
