angus50456
I have a 3010 JD Diesel that I have been chasing a running issue for a month now. Fuel pump replaced. Injectors are good. Injector pump gone though and was ok. Tractor starts hard. Will sputter, wants to run. Reves up and dies... I just found that there is return line from the last incector that goes to the fuel tank. At one time of another it was brazed were there what a leak. It is leaking again now. Would this little bit of a leak in the fuel system between the injectors and the fuel tank cause this? I can see if it was from the tank to the injectors. But a return line to the tank?
Thanks for any input
