Mutt and Jeff
with their minds running at 100mph and humping to the beat of a new holland square baler for untold hours
the technology imparted in the simple growing and gathering of some otherwise natural event is astounding.
I was just trying to google a page with a lot of farming terms to amaze myself at a second language
and this pops up
When harvesting hay or haylage we tend to think in terms of how long it takes to get the hay off the field. However, the first concern for quality hay/haylage should be how long it takes to lose the first 15-20% moisture. Forages have 75-80% moisture when cut; they will continue to respire sugars (break down and give off heat and carbon dioxide) at a high rate until the plant is dried to 60% moisture. If we want to save the energy of the starch and sugars for our cattle, we need to dry off the first 15-20% moisture as quickly as possible.
Most of the respiration takes place in the leaves. We should remember that conditioning is for drying the stems but has little impact on drying the leaves.
A wide swath has the biggest effect on rate of leaf drying. Leaves dry faster in a wide swath because:
More sunlight falling on the field is intercepted for drying. (A windrow intercepts only 25-30% of sunlight falling on the field while a wide swath intercepts 70-100% of sunlight.)
Light keeps the leaf stomates open longer, so moisture can leave through leaf openings. Since most of the forage in a windrow is in the dark, the leaf stomates close to seal the leaf surface.
Table 1 shows the losses that can occur due to making a windrow rather than a wide swath. Data indicate that starch and sugar loss can range from 2-8% of dry matter. If we assume a median starch/sugar loss of 4% of dry matter due to hay in a windrow compared to a wide swath, then the dry matter economic loss is $6.40/ton, according to current hay prices in the Midwest for large square bales.
WindrowCost-19wmmww
However, the respiratory losses of starch and sugar also increase the fiber content of the forage. If the forage was near 40% NDF (prime hay/haylage) when cut, then the 4% starch loss will increase fiber 3.4 units and lower the quality to Grade 1 hay (125-150 RFQ). Grade 1 hay is currently selling for $38/ton less than Prime hay. The value to dairy producers is about twice the price differential between hay grades.
Many farmers have switched to making wide swaths when mowing. A wide swath is the single most important factor affecting forage drying rate; it is more important than conditioning. Farmers who continue to put hay into windrows are increasing drying time and risk of rain damage. They are also currently losing about $44.40/ton due to yield and quality losses from increased respiration. Considering this dollar loss, most farmers could figure out a way to make wider swaths with their existing equipment; they should also look at wide swath mowers when replacing mowing equipment.
and this pops up
WindrowCost-19wmmww
