morgan in ar
I bought a mechanic stethoscope and narrowed the knock down to cylinder 7. I tried my bore scope again (it had grease on it last time), and the piston looked like the surface of the moon. It must be something really small in there, the piston has lots of little dimples, doesn't look really bad. I tried to run it with that plug out, hoping the compression would force the foriegn object out of the plug hole, but no luck. I can't see anything in there with the camera, either. The noise seems to keep time with the exhaust valve on that cylinder. I guess the head will come off this evening. I suspect that head will need a valve job now. If that piston is a total loss, is it possible to just replace that one?
