Tree-Farmer
I have a John Deere lawn mower that won t charge the battery, STX38. The mower works if I remove the battery and charge it before I use it.
I found the repair manual online. It says to remove the connector from the voltage regulator, start the mower and
Then check the AC voltage across the outside connectors.
I did this and am getting 42 Volts AC.
The manual says it should be 28 VAC.
It says: If the reading is LESS than it should be then replace the stator
If the voltage is OK, then replace the voltage regulator/rectifier.
It doesn t say what to do if the voltage is MORE than it should be.
Anyone had any experience with this?
If the AC voltage is more, if it s waaaay too high, does that mean it s a bad stator?
Can the voltage regulator convert and regulate the voltage if it s higher than it s expecting?
Thank you!
Thank you!
