Dumbest question ever
Assuming you are talking about mechanical injected diesels, pumps can have centrifugal governors or air-governors. Just like many lawn mower engines do. Most tractors like discussed here on YT Tractors with diesels have centrifugal governors. Some exceptions are International Harvester B-275s and Ford Majors that used air-governors.
Continnetal diesels has flyweight governors like gas engines connected to injection pumps simular to a carburator.massy harris 33,333,44,444,55,555 and case 300 all come to mind
Also, on the Neuss (German engines) used in some IH tractors and equipment that used the rotary injection pump, the governor was hydraulic. Later pumps went to mechanical governors also. A mechanical governor is a balancing device that a given throttle setting determines the pressure exerted against the weights with a spring and on a diesel engine, when the rpm's drop, the weights over come the spring pressure and give the engine more fuel to maintain the set rpm's.
On a gasoline engine, the governor does same thing except it opens the throttle valve (butterfly) in carburetor and allows more air which in turn draws more fuel through carburetor.
JDEM, I used to drive a neighbors IH B-250 Diesel with the air-governors same as early B-275s. I hated that B-250, the governor was always very slow to respond and you would be adjusting the throttle all the time. It could have been his tractor as he never maintained anything very well. The B-275s that I drove had the rotary CAV pump like the B-414Ds, much better governor response. The most sensitive governors were on the MFs with the Perkins Diesels and the CAV pumps.
