8n harmonic balancer?
grandpa Love
What would that be? I did a bit of
Google searching and make St if
what I read 8Ns don't have a
harmonic balancer. Maybe I read
it wrong......
<img
src="https://www.yesterdaystractors.com/cvphotos/cvphoto29760.png">
<img
src="https://www.yesterdaystractors.com/cvphotos/cvphoto29761.png">
a harmonic balancer is when the front pully on the engine is rubber mounted to reduce vibration. quit sure that engine don't have that. look and see , u have the tractors.
I guess to satisfy my curiosity I will have to call the seller and see why he thinks it's a harmonic balancer.... .....
he might be familiar with the newer engines that have them and not know old stuff don't use them, so just calls it that.
A wobbly front pulley can be very bad news if it was run loose until the end of the crankshaft was wallowed to a taper.
Even a new/good pulley won't stay tight then.
Only way to fix it is a different crank, or pull that one and have it welded up and turned back to size.
You are right. I had a D7 Cat and one day working under the machine, I noticed that the front pulley moved when I touched it. I started looking for a salvage buyer and lost a lotta$$$$$ , but was glad to see it loaded to go away.
I have/had them on cars and trucks and know where to look for them (as stated by others) but can't find one on any of my Ford tractors, 4 cyl 2000 thru 3910.
