Geo-TH,In
Two different people were told they needed a new furnace because they had a cracked heat exchanger by two different HVAC repairman.
I told both people to call the gas company. The Gas company will be there immediately and check for a CO leak.
This morning I went to my friends house, the guy with horses, to deliver him 2 electric space heaters, a digital CO detector and looked at his furnace.
The HVAC repairman left the hose off the pressure switch that detects if the fan is running and sucking the exhaust out of the condensing furnace. So I removed the pressure switch. When I turned it upside down, condensat ran out. That's a NO, NO. I sucked gently on the vacuum side and switch closed like it should. Business must be slow and he wanted to replace the furnace.
After removing water from switch, I put hose where it belongs, and furnace fired up. Digital CO alarm showed no CO. If there was any CO I would detect it, instant headache like I get with diesel exhaust. He's going to confirm CO by calling gas company.
WHO CAN YOU TRUST?
Have you been a victim of a repairman's scam?
I told friend he needs to clean drain line which is also used as evaporator drain that tends to choke up.
WHO CAN YOU TRUST?
