Valiant Farmer
Hi all,
Can my fergy TEA brake shoes fit my Dexta no problem?
Also right rear axle has an oil leak, quite bad. Didn't leak until I pulled axle off to replace wheel studs. Any ideas to stop the leak?
Also is the steering easy to fix with repair nut kit(has more than half a turn slop)?
Also thinking of (while I'm at it!) replacing clutch plate as when I put the clutch down the Dexta wont stop! Is that reasonably simple?
Thanks!
Joshua
Thanks!
Joshua
