in-too-deep
The static water level in my well is 3 feet from the surface. Almost a flowing well. My water lines are 8 feet deep. Which means 5 feet of head when you're trying to connect fittings before you're up to your you-know-whats in COLD well water. I know, I SHOULD have put a buffalo box shut-off at the well casing adapter right after they drilled it.
So, are there any tricks to stopping the geyser when I'm down in the hole dropping hose clamps in the mud?
Are hose pinch pliers strong enough for 1" black poly?
Dry ice to freeze the line?
Just work faster?
Pump water out ahead of time somehow? Well produces 80 gpm at a trot.
Thank you for any ideas. Planning on installed a new cattle fountain and hydrant soon.
Just work faster?
