I never saw a hose do anything like this. The 2-105 White has an engine oil cooler in the bottom tank of the radiator. I had a film of oil on the bottom windshield on the right side of the cab. I couldn't really tell where the leak was when it was running,but the frame was oily under these hoses too. I just washed it all off and wiped it down,then started it up and waited.
That hose started sweating oil. I had wiped it down a few days ago when I was using it and a while later had oil around the crimped fitting and suspected that was where it was coming from,but it appears to be weeping out then running down to the crimp.
It was leaking so fast that I couldn't even wipe it clean and snap a picture before it would start weeping again. It isn't spraying at all,just oozing out. It didn't take 10 seconds for it to get to what it looks like in the bottom picture.
