Working on a jd, but in this case I don't think it matters. The front axle has a support bar that goes back to the main case and has a pivot point. The pivot pin is screwed into the main case of the tractor and is essentially a stud. Sadly the hole is near the bottom of the oil sump, so if it wallows out, all your oil ends up on the ground. Don't ask how I know
So what would be the best fix? Currently a 7/8 stud. Drop it out for a 1" or maybe slightly bigger new stud? Or helicoil and go back original size? Will a helicoil seal when below the oil level in the sump?
Thanks.
Thanks.
