Pecosallis
The same D-17 engine and unit as my previous post. Am installing the second governor in this engine because it seems the weights pins and clips just blow right off. The gear is totally torn apart at the weight attachment point and I also have to replace the cam gear. I noticed on Combine D-17 engine the governor gear is a lot wider and goes in or onto the cam gear fully. I know that the combine weights only allow for one high speed for its operation and that it cannot be use in a regular engine.. Has anyone ever changed the weights on the combine governor and used it on the tractor/grader engine.. I looked at the D-17 engine service manual and photos show the combine (coned housing) governor on the engine. The only difference on the Model D and the combine housing is the Model D has an oil fill port on it to make it easier to add oil. Does anyone really know? BTW the first governor I put in was about 7 yrs ago.
![a274477.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a274477.jpg)
