IH SUPER W6 - CARBURETOR REBUILD
Kennyroo
New User
Hi there,
Looking to rebuild the carburetor on my 1953 IH Super W6.
Recommendations on where to send it? Was going to send to Denny's but have not seen good reviews online.
Any guidance woudl be appreciated.
Thanks,
Ken
Welcome Kennyroo!
So, what's wrong with the carb?
If it's just the usual, clogged with ethanol residue, or just needs a good cleaning, do it yourself.
There are many methods to clean one up. Stripping it down and boiling it in vinegar is a good way to get it clean and make it look good. Followed by scraping out every passage, flushing with spray carb cleaner will get one as clean, maybe cleaner then a rebuilder will.
The carbs are simple. As long as everything is there and not damaged, it should be a doable job. There is a lot of info available online as for theory, fuel circuit diagrams, float level and initial adjustments.
There are 2 types of kits, a repair kit, and a master kit. Generally the repair kit is all you need. The master kit has more parts, but unless it is in bad shape, like a worn throttle shaft, you won't need the extras or the extra cost.
One of the keys to a successful carb rebuild is having a clean fuel supply. If there is rust, trash, water in the tank, it will get in the carb. No matter how well the carb is cleaned and repaired, contaminated fuel will immediately cause problems.
I don't know of any rebuilders to recommend, simply because I never use them. I have heard some horror stories though of ridiculous charges, lost carbs, and failure to communicate.
If you decide to try, don't be afraid to ask questions. We can walk you through it.
Thanks Steve.
Was having some issues with tractor cutting out. Not sure if it's electrical or fuel related.
That said, wanted to start with fuel and get it rebuilt. Might as well be right.
Regarding the kits - do you have link where to get them?
Thanks in advance.
Ken
(quoted from post at 19:57:47 07/06/18) Welcome Kennyroo!
