I am hoping you fabricators out there will review my design. I am planning on building this manual telescoping boom for use with loader on my Ford 860.
I plan on using:
5" square tubing, 3/16" wall
4" square tubing, 3/16"wall
3.5" square tubing, 1/4" wall
4" x 1/4" plate for the hook mount
5" x 1/2" plate for the loader mounts
My tractor only has a single aux valve to lift the loader (trip bucket), so I am thinking about using a winch with a snatch block to control the lift (angle) of the boom. I think a winch with a load capacity of 2000 lbs. or higher would work fine. I plan to mount the winch to the loader frame.
My sketches are attached and hopefully the dimensions are readable.
I estimate that it will weigh ~420 lbs. and be able to lift ~300 lbs. when extended.
Please let me know your thoughts. Your collective knowledge is better than building it twice.
Thanks,
Thad
I plan on using:
Thanks,
Thad
![mvphoto16191.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto16191.jpg)
![mvphoto16192.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto16192.jpg)
![mvphoto16193.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto16193.jpg)
