(quoted from post at 20:13:20 04/30/18)
(quoted from post at 14:57:27 04/30/18) Neighbor replaced his two batteries in his 4010 diesel. Told me he had to polorize it?? something about shorting accross the regulator.. In all my years I have never done this after replacing battery... Should I??
I believe the the term he used was polorizing.. help me out..
ASSUMING the charging system has been working properly, at each and every engine shutdown, the cutout relay disconnects the generator from the battery.
There's no longer any connection between the generator output and the battery.
So it makes no difference, whatever, if you change out the batteries at this point, because they are not connected to the generator, anyhow.
As long as the battery(s) is reinstalled/replaced with the same polarity as before, the generator isn't affected.
On the other hand, if the battery(s) is reconnected with the opposite polarity nothing happens until engine startup, when the generator begins to charge and the cutout is pulled "closed" connecting the generator and battery(s) together "fighting" each other.
The battery(s) will win, and expensive smoke will be lost from the generator and/or the regulator.
