NOT(quoted from post at 14:10:52 04/05/18) the distance between the breakers will make the difference
(quoted from post at 13:41:35 04/05/18) If both breakers #1 and #2 are identical, then breaker #1 will trip first as it is the closet breaker to the panel (source of power). The current must pass through breaker #1 before it can get to breaker #2. Therefore breaker #1 will protect breaker #2
(quoted from post at 20:23:58 04/05/18)(quoted from post at 13:41:35 04/05/18) If both breakers #1 and #2 are identical, then breaker #1 will trip first as it is the closet breaker to the panel (source of power). The current must pass through breaker #1 before it can get to breaker #2. Therefore breaker #1 will protect breaker #2
Since it's AC, you don't know which way the current is flowing the moment of the overload.
either(quoted from post at 18:06:04 04/05/18) I assume this is all theoretical and not an actual design, as it would be silly. The breakers act identical, and the wires are the same size, etc.
So there appear to be 2 lines of thinking.
#1 gets the full draw first and would trip first.
#2 sees a dirtier electricity after voltage drop and going through the first breaker connections and so would see the heat up and feel like tripping
frost.
Which way is correct?
et real! At the speed of light? How many light years apart are the breakers? How fast does a magnetic or thermal breaker operate? :roll:(quoted from post at 19:34:26 04/05/18)
If voltage drops then ampacity increases to try to maintain the required watts. Low voltage will draw more current which creates heat. If more current is being drawing in order to compensate for low voltage then that current must pass through breaker #1 first which will sense the overload before it reaches breaker #2.
(quoted from post at 14:09:34 04/05/18) Example:
A modern day electric dry is a 4 wire circuit. They separate the neutral from ground as there may be a 120VAC digital display.
