old
- Location
- Camdenton Missouri
So I am working on getting 6 tires back on this old 1965 Ford 1 ton. Just mounted a good used radial tire on one of the rims with bad lug holes and then put it on the front axle and low and behold the lug nuts seem to have enough bevel to them to get it pretty well centered. The other rim has a bias tire on it and I am thinking about putting it on the other side instead of mounting another radial tire on that rim. This truck is on farm only and might get up to 20 MPH if even that fast.
Rears will have one bias and one radial in each side, side by side.
So will it drive oddly or will it be ok so low speed?
