caterpillar guy
How much hydraulics does it take to lift these newer planters, and is it pressure or volume or both? WE need a newer tractor for planting with to lift a newer planter. 8180 white 16 row. I keep thinking that if you can lift it with these older tractors at 2100PSi and 12-15 GPM is it pressure that needs to increase or just the volume to speed it up.
Talked to my local Agco dealer and told I need to have 25or more volume and 2100Psi or more to lift on the go. So which is it? If 12GPM will lift it then I add seed,fertilizer or whatever and now can't would not the problem be pressure more than volume? I would think the volume would just affect lifting speed mostly. Pressure would affect load lifting ability.
What am I missing ?
What am I missing ?
