Adirondack case guy
I have all the design and fab work done on the 2 post canopy for the 431T. I adapted the gig which I built for the 2 post on my 831C to work on this one also. It just fastens to the end of the boom on my cherry picker, and locks into two pockets on the 2 post, plus I welded in an eye to hook a come-a-long into to level it while lifting. The last couple of days I fabed a lateral support to reinforce the 2 post from side to side. It bolts down to the top of the rockshaft housing and tranny. I believe this will hold up to any accident that could accrue. There are 4 bolts that go thru the rear axles that hold this to the tractor.
Today I will cut out 4 fishplates from 1/4" plate to reinforce the bottoms of the posts where they attach to the axle.
I ran into one problem with the build. There wasn't room for the remote levers between the 2 post and the 3pt control quadrant. So I cut the levers off, with plans to reconfigure them. It dawned on me that I had stashed a set of control cables off a snow plow truck, years back so I dug them out. I will build a nice console on the RH side of 2 post for the levers and an anchor bracket down by the service valves and run the 2 cables between. Problem solved.
Once that is all done, I will prep it for paint, but can't paint until it warms up. The swing out tool carriers on the sides of the tractor, and the grill guard are done also.
I have plenty of other projects to keep me occupied until then.
