Question on loader for tractor
MtFord88
New User
I have a 54 ford jubilee I just picked it up Im looking for a loader, I found one of off a 9N Will that mount up and work on my tractor
Will have to rework the mounts as the jubilee is a bit longer than the 9N, have to do it at the back end as you would need the front end to stay same place.
Here is my experience with doing something similar: I found a Davis loader from a 8n, it mounted to the NAA tractor fine,
however a few pieces were modified so I wouldn't have to cut
the brake pedals, also custom floor boards where made. It did
work. However the hydraulic valves on the right side prevent
you from getting onto the tractor from that side. Also I had to
take the front lights off as they interfered with the arms.I have
lived with it for several years. But truthfully it took away from
the enjoyment of the tractor.
Fast forward to last weekend, my brother inlaw turned up a 54
with a Dual loader, it is a lot better, and seemed to flow with
the tractor better. It retains all of the front end sheet metal and
headlights. You can also get on the tractor from either side.
This biggest issue I had with it was they gut out the front grill
to clear the hydraulic pump.
1954 is an NAA not a jubilee. Almost the same but not the same since the Jubilee was the 50th year model and did in fact have a different emblem and yes I am a purest.
That said as for a loader to fit from a 9N maybe, maybe not since some where made just for the N series and other for the N series up to the 801 series just had different mounts
No, not a bolt and go. Look for one off a Jub or 600 like a 703
loader. Smaller bucket. Easier on front end and your arms with
no power steering
I have a freeman loader available for cheap that came off a 4 cyl 4000. It is the trip bucket type, but it works for
many jobs. Southern Indiana.
