1974 Case 446
Have you tried NAPA? I'll be going to the local store this morning, I'll ask if those are available. I've heard Onan parts are expensive.
Not a cheap engine to buy parts for.
I put a Kohler 20 HP command series in mine, made it a pleasure to use.
It will go through foot deep wet grass like nothing.
Straight forward bolt on for the hydraulic pump and deck clutch on mine although mine had a Kohler k series in it before the swap.
Only obstacle was the hood needed to be trimmed and raised a few inches.
(quoted from post at 05:41:40 10/25/17) Onan parts are expensive. I stuck $1000 in parts and machine work on the engine in my 446 I did the assembly.
Oh my that sounds very expensive :shock:
(quoted from post at 03:57:03 10/25/17) Have you tried NAPA? I'll be going to the local store this morning, I'll ask if those are available. I've heard Onan parts are expensive.
I'll LSO check Napa, thanks
http://boomersonanparts.com/
contact this guy. Has lots of used as well as new parts available and really knows Onans. Usually the cheapest source and can help with any info you might need.
