So was going to replace the crankshaft sensor on a 2000 Oldsmobile intrigue, simple enough, looked on the net and it's located right behind the starter. Went to remove the starter bolts, and these bolts were tight tight, had to use a cheater, the long one came out, but I broke the short one, this is on an aluminum block. My question is, what are my best options to remove the bolt, is there something I can pour down the hole to eat away the corrosion, and help to ease the bolt out? Can you weld to it without making it worse in the aluminum? Or do I bit the bullet and start drilling? I do have access to muratic, and sulfuric acid.
