kleine39kermit
I have the alternator off, It is a Delco Remy; 8B28 12volt neg. also has 11C 2491 37A on it.
On the back end; 1 large terminal with nut. I would guess this where you would connect the live (hot) wire from the battery/Amp meter.
then there are 2 blade type connections on the rear side. looks like they have the numbers 1 (r) and 2 (f).
The guy I got this tractor from had wires from the battery side of the ignition switch to the large terminal and to #2 f. Both wires were live when the battery was connected but alternator did not work.
The alternator might be shot now. Let me know what you think.
