perkin thrust surface?
mmidlam
I have a 3 cylinder perkins where the thrust bearing have fallen out.The thrust surface on crank is worn and the thrust bearing mounting area and cap is worn. Where or can can the block and cap be repaired?
There is one oversize thrust bearing. A new crank isn't very expensive , i'm not sure sure what you can do for the block damage though. You could have a new main cap fitted.
Best to have a machine shop look at it.
Might get lucky and the wear is minimal, or could be worn well beyond spec visually can sometimes be hard to tell.
Have you figured out yet what was causing the excessive load on the crank?
Sucks to have to do things twice.
