How to clean rusty rims?
tomstractorsandtoys
My 4230 started leaking some fluid at the valve yesterday. Today we had the fluid pumped and the tire removed. The rim is more rusty than I like and will need wire brushed before repainting. What should I do to remove the fluid on the rim? Is just power washing enough or will the new paint soon come loose? Is there some kind of rust preventive that should be applied before primer and paint? I also have a WD45 to do the same thing to. Thanks Tom
I remove the major stuff with a surface grinder and/or wire wheel. I have tried different paints, "rust reformer", etc. The best luck I have had is since I got my pressure washer. It's not steam, but close to it. The combination of pressure and heat seems to really get the salt out of the pores. It also peels grease, and will start to peel apart a fan belt. Guess how I know?!
I just got dun with my rims. they had a lot of heavy thick rust that I removed with a chisel bite in and electric hammer drill. It worked better then an air chisel, then wire wheel. I then used Rust Converter. got it on Amazon. It converts the rust and stops it form reforming. then paint with an oil base paint
2X what Rons b said. You are going to find a lot of very thick stuff that will wear a wire wheel right out. And you need to put the acid right to it to kill the rust. Some guys will tell you to paint with a heavy coat of rustoleum or something like bed liner, but if you don't get the rust off first you are just making a better environment for the rust.
New rims for around $250,,,how much time are you going to spend on them,,and how much good are you going to end up with?? I don't waste time on rusty rims...start out new and keep the calcium away from them..
I use an angle grinder and a chipping hammer and some times an air hammer. When done I then spray it with pickup truck bed liner spray that way I know it will be there a logn time plus makes a good thick coating to protect the tube
They had a wheel abrator where I worked that used lead pellets that removed paint and rust. Hal
sandblast,if you have metal left... prime, paint,and done.
there is some sort of stuff to apply for rust after sandblasting also.
