ThundermanND
I took my 8N to a shop to be blasted and painted and that worked out fine, actually terrific. When the shop guy put the rear wheels back on, he busted off two lug nuts on the same rear wheel. They are opposite each other but my question is whether or not I need to yank off the brake drum assembly and have the lug nut bolts pressed out or if I can get along with it this way. It will not be used for work, more just show or parades. This company is used to working on Semi trailers so I'm sure they had the air pressure up higher on their compressor.
What say you?
What say you?
