old
- Location
- Camdenton Missouri
So saw another Case VAC listed on Craig's list and was only about 20 miles from me. It was locked up but 24 hours of ATF fixed that. Cylinders where dry so locked from sitting for a long time. Did not have the left hand rear tire on it when I got it but had a 11.2X28 laying around and put it on the rim today and then on the tractor. Not sure of the year since there is no serial number tag on the dash so need to figure out how to find that out. Steering rod is bent badly but think I have one or 2 of them laying around that I can use to replace it. Also back side covers are missing and I have a couple of them I will put on. Grill is not the best so I'll put on the best of the ones I have from the parts tractors. Also the distributor cap has been off of it for years to the distributor is badly rusted and I will probably have to get a used one for it. But I have pulled it off and dumped it out since it was full of water and then filled with ATF and that has helped a good bit. Front tires are shot and one front rim is bad but I also have other rims around to fit
![a241300.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a241300.jpg)
![a241301.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a241301.jpg)
![a241302.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a241302.jpg)
