Geo-TH,In
When it comes to my vehicles I rotate and balance every other oil change, 6K. Never considered rotating my dump trailer tires. I noticed the tires on back axle had considerably more wear than the front axle. So I decided to rotate them today.
I also checked, the spacing between axles, they are same for both sides.
Tire pressure is as it should be 65 psi.
I'm thinking the rear tires slide more than the front tires when turning because the front axle has a few more pounds on it because you need a positive tongue weight. If my theory is correct, do you think lowering the air pressure on rear tires will allow the side walls to flex in a turn instead of scuffing off rubber? Opinions about air pressure.
George
George
