super99
Is there any way to check a condenser? I stopped at Napa after work and got a tune up kit for IH 12 volts thru 1958. I changed the points and condenser, dropped the brass screw for the points in the grass and couldn't find it, had to go steal a screw out of the JD 70 distributer to get them put in. Still no fire. I pulled the coil wire and laid it against the loader frame and cranked it over and it has spark there. Power to the resistor, test light lights up on the stud thru the side of the distributer. Did I get a bad condenser? I have had new ones that were bad before, maybe again?? What else to try?? Thanks, Chris
