old
- Location
- Camdenton Missouri
So I went to the friend place today to see if I could get his 1 ton running. Tried spraying carb cleaner in the TBL to see if ti would try to run and that was a no go. I pulled the center wire from the cap and put a spark plug in it and used vise grips to hold it tight to a good ground. I have NO spark. So we replaced the ignition module, the coil, cap and rotor. Still no spark. So what else might it be?? I'm thinking either pick up coil which is in the distributor or the ECM which if it is the ECM that will cost a good bit of $$
Thanks and hope some one can give me some ideas as to what maybe wrong
