Fertilizer revisited
Mark Poss
Thankyou for all the advise. I am only check rowing a couple of acres for fun. What do you recommend I spray on the ground ahead of time?
Thanks again, Mark.
160 lbs nitrogen 60 lbs phosphorus 120 lbs potash fertlizer needed to grow 100 bushel of corn is the time tested rate.
So, what do you have available, if you are spraying fertilizer that is often a bit spendy broadcast deal. Works fine, just more dollar.
How much corn yield are you trying to get, 90, 120, 175?
Is your soil pretty good, or worn out? Do you know if you already have good P or K so you don't need so much of one, or it really needs the help badly?
There are 100 different ways to do it, all work, some are easier and cheaper one way but not the other. It would help to know what you got going on to give you more specific help.
Paul
