super99
I have a 400 Farmall with a loader on it. It only gets used for loader work, so it doesn't get many hours on it. I replaced points, condenser and spark plugs last Dec and it started and seemed to run OK. I was trying to move some gravel the other night, and it would start missing under a load, sounded like it was running on 2 cylinders. I just had it at a fast idle and as soon as it got a load on it, it would start missing. Sometimes it would die when opening the throttle and sometimes it would miss and then come out of it. The motor is weak, it likes to foul spark plugs. I put a set of non-foulers on the plugs a few years ago and it helped a lot. I took the plugs out and cleaned them and they were all wet with fuel or oil, no sure which. I still have more to do, guess I'll buy another set of plugs and see if that helps. Any ideas?? Thanks, Chris
