justoneoar
New User
1986 3208 cat
Has been sitting two years now has two flat tires on drivers side with lean to drivers side ,on small side hill
Changed fuel & filter
Added in line fuel pump to assist ,pumped fuel to all cracked injector lines ,retightened ,retightened t valve at top of pump oil was at just below add mark guessed that was because of lean?
Tried starting with no ether turned over hard ,removed starter added new solenoide ,reinstalled starter turns over brisk with small white smoke at exhaust no fire
Little shot of ether it made it turn over faster ,tried starting turning over starte for 5 to 15 second bursts with ether every 3 or 4th time but no fire ,wore two battery's down ,no fire
Charged battery's over night ,now with fresh battery and bolster cable to tractor starter ,turns over but quickly slows down
No fire at all and ether doesn't speed up turn over now
First question ,there is no external low oil alarm and oil pressure gage never worked
Is it possiable for something internal (low oil cut out?
Thanks in advance for any and all advice
