Howard Parker
Need to help a friend wire a farmall H right now there is a wire run to the coil from the kill switch doe it go the +
or - side of coil? then a wire comes from generator to the amp gauge which side does it go on? then a wire from
the amp gauge goes to the battery? or the starter? also forgot where should the power wire for the kill switch
come from? also where does the lights get there power from? thanks Howard
