Disconnect/remove all things that bridge the gap. put rolling splitting stands on the front (might require a sub frame to
get to the front bolster). Support the torque tube with wooden cribbing. remove the bolts and starter. Pull apart.
Remove flywheel replace the core plug. Check/replace clutch/p-plate/TO bearing. Go back together. Jim
I do not think there are any. two from the rear at the top, and the rest from the front to the torque tube. (Best memory). Jim
As Jim said and to add the only thing that gave me problems was the steering shaft.
The universal did not want to come apart after 60 years, I cleaned it all up and had to shock it good with a hammer. It was worn to the point it was not worth saving so I installed new ones. Just did the same split last month, not a nice place for a freeze plug! oldiron29
