I got the MH44 EFI running yesterday.
The head studs still leaked, posted about that.
The new wiring works fine, computer fired it right up.
I am real happy with the power steering running of its own pump now. The tractor steers easier than it ever did even at idle. I would not try to run power steering off a priority valve on a tractor with a low flow or low pressure hydraulic again.
The engine is very quiet now. The governor had thrown a weight and that nicked the cam gear, I cleaned that up when it was apart. The studs that I had installed the crank sensor with were too long and rubbed on the front of the timing cover, that is fixed. I also think the old hydraulic pump was noisy, we will see how the new one is when I get it installed.
Thanks for all the following on this, it has been a challenge.
