clark cfy20 forkfilt
cdv
working on a clark anyone know what points go in a model cfy20 ser 48615864 with continental 4cly falthead gas engine letters b.dr after cfy20 point look just like massey 35 tractor to me thanks cdv
It could have a Delco or Autolite distributor. A real auto supply can match them up.
Check the distributor bushings, if it's the distributor that goes in the center of the head, they run very hot, tend to dry out the grease and wear the bushings, then the points won't stay set. If this is something that gets used a lot and needs to be dependable, might consider an electronic conversion. Changed the one at work over to electronic many years ago, haven't had the cap off since!
