Update Kohler and broken tap
IA Roy
I went out this afternoon and heated the casting around where the tap was broken off in the casting. I only have a small propane torch so it took quite awhile and didn't get all that hot. I then doused it with my mix of penetrating oil. Half mineral spirits and half ATF. I then used a pin punch and a hammer to work the tap around in the hole. First one way and then the other. Blew it out with air hose and doused it again. Repeat several times. After about 45 minutes to an hour I had the tap out without damaging the casting.
Every time I accomplish one of those things, I hang it up on the wall to remind me; Don't give up.
Congratulations! I save old difficult to remove pieces in box, just put too much work into them to throw them away, I guess. Every few years they get thrown out.
glad it came out, I do have a set of tap extractors that work very well when that happens,, only used them once here but have used them several times for friends in that situation, have removed every one even one they tried getting out
cnt
