Electric Wheel Hubs
RBMI
I am working on a machine that has hubs made by Electric Wheel. The casting number is Q545. I need to replace 4 hubs. I am fairly certain these are obsolete. The machine is a Bombardier Ski-Dozer. The hubs have wheels and tires mounted on them that serve as the idlers for the track. 5 bolts on a 4.5" bolt circle. Inner 14136A/14276 cone/cup. Outer 09067/09196 cone/cup. Any ideas?
sounds like they could be a trailer axle hub
4.5 5 bolt hubs were ford/dodge bolt size if my feeble mind remembers
you might have to use a sleeve on the axle if the bearing centre is to big but should get you going again
back when them Bombardier Ski-Dozer were made they used outside sourced parts and over time started producing their own parts as they got bigger
how old is yours
Just take the bearing races out of the hub and measure the ID and the spacing between the races. Then with the bolt pattern and size/spacing you can go on line and find the hubs you need. Most of the older wagons have pretty standard hubs. The only odd ones where the ones that used the rim as the dust cover. They are harder to find. Most Electric wagons/hubs are pretty common sizes.
Here is a web site you can look for your hubs by size/dimension.
https://www.baumhydraulics.com/home.php?cat=9
Baum Hydraulic
