FlatFenders
In the process of converting to 12 volts, I discovered that there are no wires connected to my ammeter, other than one that passes through a "loop" on the back. The only wires near by were connected to the resistor board. The ammeter worked with the generator and I routed the large red wire through the "loop" on the back of the ammeter thinking it must be some sort of inductive pick up? Anyway, it does seem to work. I removed the original wiring harness and saved it of course since it is still in pretty good shape.
Did I just get lucky that the ammeter works or are there some other wires hidden behind the original resistor board that I can not see?
