I was told by JD, the Tier 4 engines in their 45-75 hp. range, are guided by an onboard computer, and every so many hours, the engine has to heat up to 1200 degrees to burn off particles in the diesel particulate filter (DPF). Sounds hot, and I'm thinking it could be a fire hazard in the right conditions. Just curious if anyone has any experience with these new EPA engines and how they perform? I'm also told if the computer malfunctions, the engine shuts down and has to be reprogrammed in order to start. If the filter gets ruined that is about a $1,500 replacement. Maybe it's time for a gasoline or natural gas burning tractor. Your thoughts?
