Geo-TH,In
I recently purchased a tractor with a honda GX620. Is there a good oil filter that
will fit the engine that doesn't cost as much as a honda filter? I'm not interested in
using a Fram. Not interested in a lesson on using OEM filters. What filter do you use
on your GX620?
I went to Auto Zone and they had a bosch filter for $7. I looked at it and it was too
small. So much for cross referencing filters. The filter currently on the GX620 is
about 3" OD and 2 3/4 long.
I use a AC delco filter on all my GM vehicles PF47E and they only cost $5. A honda
filter is over $10. If I had my filter wrench handy, I would remove the old filter and
see if the delco would fit, it measures 3" OD and 3" long. Not sure if the threads are
the same size.
on your GX620?
the same size.
