super99
OK, time has a way of flying by. We put our house up in 2002. I had the basement door installed by a contractor my son was working for at the time, he didn't use treated wood. I put silicon caulk around the edges and filled the gaps with it. I primed it and never got back to paint over it. I painted 2 door frames upstairs today and decided to paint the sliding door frame also. After looking at it, I need to do more than paint. On the bottom left, the wood is starting to go bad and some of the silicon is loose in other places, I scraped that off. Is there a outdoor wood filler that I can use on the bad spots and then paint, or should I just get a roll of brown aluminum trim coil and cover it as it is? This week was shutdown at work, I have the combine ready to cut rye, but it's probably a week away, so I can work on it after work and get this taken care of. Chris
