I have an auger on a gravity wagon I use for dry fertilizer. The auger is powered by a hydraulic orbit motor. I believe the orbit motor is leaking some oil out of the seal around the output shaft. A few questions:
1) How are most augers attached to the orbit motor shaft? I need to pull the auger off the shaft to pull the orbit motor out. I do see a hole in the auger shaft, can't drive anything out.
2) What is the procedure to replace the oil seal? The orbit motor is an Eaton.
3) Where is the best place to look for an Eaton orbit motor seal?
Thanks........
Thanks........
