"If tractor sits for a few day, more than half the oil in the filter will slowly drain back the crank case."(quoted from post at 06:58:54 03/01/15) I have a Jubilee. It was converted to a spin on filter before I bought it. The engine was also totally rebuilt. Now some people say there is something wrong inside the engine, something not tight enough. Some people say it the filter's fault. The filter is horizontal. If tractor sits for a few day, more than half the oil in the filter will slowly drain back the crank case. So when you start up, it takes about 10 seconds to fill the filter, 10 seconds before oil pressure builds. I've tried every filter out there. Slowly the oil will drain back. You can see the extra oil on the dipstick. Start engine and then dipstick oil level will be correct. Keep in mind, I've tried every filter out there, same issue.
To cut down on the time it takes to fill the filter, I found the smallest filter, a delco filter. It too will drain back. Because it's smaller, it takes less time to fill up on start up. I had to remove the filter to put a new starter on. Took filter off, no oil leaked out of filter.
I'm not about to take engine apart. I'm not sure it the engine's fault. I would like to see if problem goes away, but I don't have what it takes to convert back to a can. So my solution is to use full synthetic oil. Hoping it gives better dry start up protection.
There will be some who say the filter I'm using is the problem. There is something loose inside the engine. I really don't care.
My two cents. Save your money, DON'T CONVERT TO A SPIN ON.
on't know who you are directing that question to, George? If me, then I will say that pressure relief is not anti-drain back. Pressure relief is to allow a full flow type filter to be bypassed in the event the filter clogs enough to stop oil flow, the idea is that unfiltered flow is better than no flow.(quoted from post at 09:46:30 03/01/15) I think I saw a relief valve at the end of the delco filter. Same filter used on today's cars. So wouldn't it have a pressure relief valve?
I'm just saying stay with the OEM can filter. I have no plans to do anything with the can on my farmall C. Some even say the spin on filter cost them an engine. Got a hole poked in the spin on filter when brush hogging and oil leaked out.
What is the big deal converting to a spin on filter? I like the can filter on Farmall. It gives me an opportunity to see what things look like, metal filings, dirt.
ull flow, but not spin-on.(quoted from post at 12:36:58 03/01/15) If I'm not mistaken,the Jubilee came with a full flow spin on filter.The 8n's filter is a bypass type and there is a screen on the drain plug that goes around the sump and is considered a filter also.Mark
have to disagree George, as anti-drain back affects only the inlet to filter & not the center tube outlet, so they will all drain back to half full on that basis alone. If anti-drain back isn't functioning it will drain down to less than one half. Look at the oil passages pictured. Parts you need are shown in other pictures.(quoted from post at 15:07:16 03/01/15) Jessie, the delco filter I used was a sustitute
for the Napa gold filter I was using. It has both
anti drain and by pass. It will slowly drain
back, level with the hold that threads to the
tractor.
Reguardless, I may some day find the parts and
return my tractor to OEM filter to see what
happens. Bet anything I won't find extra oil on
the dipstick using OEM can filter.
Do you have instructions on how return it to the
can filter and what filter it would use?
I got to test the air intake heater on jubilee
today. 8 inches of snow. Tractor didn't skip a
heart beat under full load. Now I need to reset
the carb back to summer and return the plugs back
to white.
hat can I say?(quoted from post at 19:35:19 03/01/15) My Dad told me their '53 Jubilee came with a spin on.Mark
