My spreaders deck has finally disintegrated. Surprisingly the steel is mostly ok...just a couple cross members to replace. The sides are good and the apron slats /angle and chains are fine with a bit of time on the press straightening.
What should I use to re deck this? 3/4" PT ply? The original was 3/4" ply with uhmw or some plastic / vinyl over it all...both sides actually. Unfortunately its 5' widex about 16'...I'll need to join a 1' length on one side and join the plywood on a cross member.
It looked like the old deck was glued down to the cross member with building adhesive...there were no fasteners???
What would you do??
Thanks, Grant
What would you do??
Thanks, Grant
