How to start a Sidena Mexican made tractor
Angie S
New User
I stumbled on a Sidena Mexican made tractor and according to all the posts there is not a manual for it. Once we drain the old diesel and add a new battery, (my neighbor is a small engine expert,) how do we start it. The man who owns it cannot remember the steps.
Thanks to anyone who can help.
A quick search on YouTube indicates that it's a Russian designed tractor built in Mexico.
The engine looks a LOT like a Belarus. Chances are if you can find someone with a Belarus or a manual for an older Belarus, you can figure out how to start it.
looks like it may be the same as a belarus 250. or
try T 25 traktor in your searches. if it is its
dead simple to work on/use once you figure out the
shifting sequence.
I think manuals are available from this site for
the belarus 250.
there should be a decompressor on it.set the
throttle about half get the engine spinning and
disengage the decompressor.
make sure there is oil in the injector pump.
did a little more looking they built at least 3 different models.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=orphans&th=524
how many cylinders is it? is it air or water cooled? model number?
You are correct,it's basically a 250 Belarus,but actually a little more refined,nicer looking castings.Operates identical to the 250.
I just found a video on the Belarus 250. It is the 310 and it is air cooled. I hope I can find a manual on it.
Thanks all for your help!
http://www.yesterdaystractors.com/BEO250AS_10521.h
tm
heres the manual and more parts are becoming
available through MTZ but you will have to ask.
http://www.mtzequipment.com/
